Dear support,
As I understood according to the DS of the LTC1733, the CHRG pin becomes active (turn to 'low') as soon as there is power-in thru Vcc, meaning that the charge cycle started.
It means that if the battery is disconnected from BAT pin, it doesn't affect the CHRG pin.
I can also measure it on our board. When Vcc becomes 5v then CHRG pin become low, even when BAT pin is disconnected.
Is there any kind of indication which can indicate that the BAT pin is disconnected and the charge current is actually zero?
BR,
Yinon
