LTC6810 CRC Problem
Hi People,
I am attempting to build a rudimentary BMS using the LTC6810-2 monitoring chip. Unfortunately, I cannot communicate to the chip because I am not understanding the Packet Error Code (PEC)  generation using Cyclical Redundancy Check code provided in the datasheet. I tried looking into CRCs and how to use them properly, but nothing seems to work. It has been a good couple of weeks now and I am losing hope. Would be amazing if someone could save my day.
Thanks
Top Replies
    on Jun 20, 2019 9:11 AM
    Have you checked  the LTSketchBook ? You will be able to find PEC generation code in 681x library for your reference. This might help you get a clear idea on PEC generation.
    Thanks
    Abhishek
  • Here is my code (slightly modified from the LTSketchBook):
    // PEC CRC15 table
    static const uint16_t LTC6810_crc15Table[256] = {0x0,0xc599, 0xceab, 0xb32, 0xd8cf, 0x1d56, 0x1664, 0xd3fd, 0xf407, 0x319e, 0x3aac,  // precomputed CRC15 Table
    	0xff35, 0x2cc8, 0xe951, 0xe263, 0x27fa, 0xad97, 0x680e, 0x633c, 0xa6a5, 0x7558, 0xb0c1,
    	0xbbf3, 0x7e6a, 0x5990, 0x9c09, 0x973b, 0x52a2, 0x815f, 0x44c6, 0x4ff4, 0x8a6d, 0x5b2e,
    	0x9eb7, 0x9585, 0x501c, 0x83e1, 0x4678, 0x4d4a, 0x88d3, 0xaf29, 0x6ab0, 0x6182, 0xa41b,
    	0x77e6, 0xb27f, 0xb94d, 0x7cd4, 0xf6b9, 0x3320, 0x3812, 0xfd8b, 0x2e76, 0xebef, 0xe0dd,
    	0x2544, 0x2be, 0xc727, 0xcc15, 0x98c, 0xda71, 0x1fe8, 0x14da, 0xd143, 0xf3c5, 0x365c,
    	0x3d6e, 0xf8f7,0x2b0a, 0xee93, 0xe5a1, 0x2038, 0x7c2, 0xc25b, 0xc969, 0xcf0, 0xdf0d,
    	0x1a94, 0x11a6, 0xd43f, 0x5e52, 0x9bcb, 0x90f9, 0x5560, 0x869d, 0x4304, 0x4836, 0x8daf,
    	0xaa55, 0x6fcc, 0x64fe, 0xa167, 0x729a, 0xb703, 0xbc31, 0x79a8, 0xa8eb, 0x6d72, 0x6640,
    	0xa3d9, 0x7024, 0xb5bd, 0xbe8f, 0x7b16, 0x5cec, 0x9975, 0x9247, 0x57de, 0x8423, 0x41ba,
    	0x4a88, 0x8f11, 0x57c, 0xc0e5, 0xcbd7, 0xe4e, 0xddb3, 0x182a, 0x1318, 0xd681, 0xf17b,
    	0x34e2, 0x3fd0, 0xfa49, 0x29b4, 0xec2d, 0xe71f, 0x2286, 0xa213, 0x678a, 0x6cb8, 0xa921,
    	0x7adc, 0xbf45, 0xb477, 0x71ee, 0x5614, 0x938d, 0x98bf, 0x5d26, 0x8edb, 0x4b42, 0x4070,
    	0x85e9, 0xf84, 0xca1d, 0xc12f, 0x4b6, 0xd74b, 0x12d2, 0x19e0, 0xdc79, 0xfb83, 0x3e1a, 0x3528,
    	0xf0b1, 0x234c, 0xe6d5, 0xede7, 0x287e, 0xf93d, 0x3ca4, 0x3796, 0xf20f, 0x21f2, 0xe46b, 0xef59,
    	0x2ac0, 0xd3a, 0xc8a3, 0xc391, 0x608, 0xd5f5, 0x106c, 0x1b5e, 0xdec7, 0x54aa, 0x9133, 0x9a01,
    	0x5f98, 0x8c65, 0x49fc, 0x42ce, 0x8757, 0xa0ad, 0x6534, 0x6e06, 0xab9f, 0x7862, 0xbdfb, 0xb6c9,
    	0x7350, 0x51d6, 0x944f, 0x9f7d, 0x5ae4, 0x8919, 0x4c80, 0x47b2, 0x822b, 0xa5d1, 0x6048, 0x6b7a,
    	0xaee3, 0x7d1e, 0xb887, 0xb3b5, 0x762c, 0xfc41, 0x39d8, 0x32ea, 0xf773, 0x248e, 0xe117, 0xea25,
    	0x2fbc, 0x846, 0xcddf, 0xc6ed, 0x374, 0xd089, 0x1510, 0x1e22, 0xdbbb, 0xaf8, 0xcf61, 0xc453,
    	0x1ca, 0xd237, 0x17ae, 0x1c9c, 0xd905, 0xfeff, 0x3b66, 0x3054, 0xf5cd, 0x2630, 0xe3a9, 0xe89b,
    	0x2d02, 0xa76f, 0x62f6, 0x69c4, 0xac5d, 0x7fa0, 0xba39, 0xb10b, 0x7492, 0x5368, 0x96f1, 0x9dc3,
    	0x585a, 0x8ba7, 0x4e3e, 0x450c, 0x8095
    // Function to calculate the PEC code for given data bytes and return the two PEC bytes
    void LTC6810_pec15_calc(uint8_t len, uint8_t *data, uint8_t *result)
    	uint16_t remainder,addr;
    	remainder = 16;													//initialize the PEC
    	for (uint8_t i = 0; i<len; i++)									// loops for each byte in data array
    		addr = ((remainder>>7)^data[i])&0xff;						//calculate PEC table address
    		remainder = (remainder<<8)^LTC6810_crc15Table[addr];
    	result[0] = remainder >> 7;
    	result[1] = (uint8_t) (remainder << 1) & 0xFE;
    Works fine, just make sure you have the command bytes setup correctly - for example to send the read config command RDCFG to device addressed 0 you need four bytes, byte 1 & 2 are the command with address and byte 3 & 4 are the calculated PEC from the two command bytes:
    bytes 1 & 2 = 0x80, 0x02
    put these two through the PEC function and you should get the following two PEC bytes:
    bytes 3 & 4 = 0x5B, 0x1B
    Then clock in the 6 config register bytes and two returned PEC bytes and see what you get.
