How to test LTC4291-1
Hi we have designed board based on LTC4292 and LTC4291. Earlier i was using LTC4291 and LTC4291 GUI application but since LTC4291 needed programming after each power on reset, i went with LTC4291IUF-1#PBF which is pre-programmed. I want to know how do i test? Do i need to use the same LTC4291 application or separate application is available for LTC4291-1?  if i try to use the same LTC4291 GUI application then it will load the application again. I am little confused how to proceed.
