LT1308B
I designed the circuit dc-dc step up using the ic LT1308B. I assembled it into the breadboard but it didn't work? or I have to assemble it into the PCB. It will work. Thanks.
  • Hi, iamtomz,
    The LT1308B comes in two different packages. Depending on what package you have, there is a suggested layout in the datasheet, figure 6 or 7.
    Both layout figures suggest you need a PCB. I'd suggest you start with a PCB, and follow the datasheet suggested layouts as close as possible.
    At the end of the day you cannot use the design in 'breadboard' mode, you will need a PCB.
    Cheers!
