LTC3806
Why does the minimum input voltage of the LTC3806's Vin pin not be as low as 10V as mentioned in the data sheet?
The actual situation is that in the simulation, as long as the voltage of the Vin pin is lower than 15V, the chip will not work, instead of the minimum input voltage of 10V as written in the data sheet. How can this happen? Does anyone have any explanation, thank you very much!
The input voltage of my circuit is lower than 15V. How can I make the chip work with the Vin pin below 15V? Ask for help!
Here are some screenshots of the chip's data sheet.
