Diode bridge design for LTPoE++ PD
My customer is designing the LTPoE++ PD using the LT4275A for 90W power application.
The customer is designing with reference to the DC2093A-A demo board.
   1. Do they have to use two diode bridges for each pairs ? why ?
   2. Can they use only one diode bridge by combining data pairs and spare pairs? why?
Thnaks.
JH
Parents
    on Feb 25, 2019 6:15 PM
    Hey JH,
    IEEE 802.3af/at/bt requires the PD to be capable of receiving power from either pairset, the data or spare pairs, and to polarity correct the input. Polarity correcting requires a diode bridge, and receiving power from both pairsets requires two diode bridges. I would recommend your customer to use the LT4321 ideal diode bridge controller, this part was specifically designed for high power PoE.
    • Yes, they should use two diode bridges or an ideal diode controller. This maintains compatibility with IEEE standards, which allows PSEs to power different pairs with different polarities.
    • This would no longer be IEEE compliant, and would limit interoperability with different PSEs. If this is a closed system and your customer knows exactly which pairs will be powered and what polarity, then interoperability and compliance may not be required.
    Best Regards,
    Eric
Reply
    Hey JH,
    Best Regards,
    Eric
Children
No Data
