Messrs Analog,
could you provide the unit weight for the following p/n:
- LTC3639
- LT8630
- LT8631
- LTC7138
Best Regards
Luigi
LTC3639
Recommended for New Designs
The LTC3639 is a high efficiency step-down DC/DC regulator with internal high side and synchronous power switches that draws only 12μA typical DC supply...
Datasheet
LTC3639 on Analog.com
LT8630
The LT8630 is a current mode PWM step-down DC/DC converter with internal synchronous switches that provide current for output loads up to 0.6A. The wide...
Datasheet
LT8630 on Analog.com
LT8631
The LT8631 is a current mode PWM step-down DC/DC converter with internal synchronous switches that provide current for output loads up to 1A. The wide...
Datasheet
LT8631 on Analog.com
LTC7138
The LTC7138 is a high efficiency step-down DC/DC regulator with internal power switch that draws only 12μA typical DC supply current while maintaining...
Datasheet
LTC7138 on Analog.com
Messrs Analog,
Best Regards
Luigi
For LTC parts on the material declaration page, click on the part number. It will bring you to a PDF, the weight is on the PDF.
