I am confusing about STAT pin of LTC4413 series.
Could anyone help me to clarify about this.
Many thanks in advanced!
This pin is an indicator of which diode is conducting. The operation of the STAT pin depends on the mode that has been selected using ENBA and ENBB pins. Please refer to table#2 on the page#11 of the datasheet.
Table above is just for an example.
As you say: this pin is an indicator of which diode is conducting so in the table above Isnk=0uA means active low? Isnk=11uA means active high? I do not see the relation when Diode A forward bias and Diode B forward bias. How about both Diode are Reverse Bias? Both are Forward Bias?
If ENBA and ENBB are Low and both Diode A and Diode B are forward biased, Isnk will be 0uA where as if both the diodes are reverse biased, Isnk will be 9uA.
