LTM4615
I am using LTM4615 regulator with spartan 6 FPGA. I am facing an issue, when I short test the VOUT1 Pin (that is +1.2v output) with the GND pin then these pins shows connectivity. But when I turn on the regulator then there is not any irregular behaviour, everything works fine, FPGA is working properly. I want to ask that does these pins shows connectivity or not or its design issue which I have to resolve.
Thank you,
  • Hi AhtishamKhan,
    Thanks. I was curious, can you provide more detail on the method for performing your 'short test'?
    From Vout to GND, externally there is the load impedance and internally there is the impedance of the internal output cap, inductor and top & bottom mosfets. If for example you use a DMM on ohm-meter setting to measure between Vout1 and GND you should see a significant resistance (ie 5.6k measured on the demo board with no attached load) from the output cap and internal switch node impedance to GND. Note also for your measurement technique for the 'short test' the measurement polarity as there is an internal body diode for the bottom fet from GND to the switch node.
    If the part is starting up and operating fine and there really were a short (low enough of a load on the module that it does not reach its current limit) then it would be expected that the short would be external to the module, to investigate that further you could check input current (if accessible) as an comparison indicator.
    Thanks.
  • Hi SYong,
    I have attached my design in this reply and also that image of short test in which I get the resistance from VOUT1(+1.2v_F in my design) to GND, This measurement is taken against the capacitor C271. I am getting these values of resistances from VOUT to GND.
    VOUT1(+1.2v_F in my design) to GND         4.5 ohm
    VOUT2(+3.3v_F in my design) to GND         193 ohm
    LDO_OUT(+1.8v_F in my design) to GND     6.29 kohm
    When I turn on this regulator, then the amount of current flows normal. No large amount of current flows through the regulator and FPGA attached to this regulator is working fine.
    Design.pdf
  • Sorry for the delay. Is the resistance value measured the same if polarity of the DMM probes is reversed? From measurements on the LTM4615 standard demo board the DMM resistance measurements across the outputs with the module off should be in the kOhm range. I believe from your measurements that the behavior might possibly be due to loads connected to the module outputs, is there a way to disconnect the loads from the circuit or do you have a board without the module stuffed to check this?
    As another small comment, I also noticed that the COMP pin default cap (not stuffed) value is 0.1uF, I would recommend making the default value lower such as 10pF or 100pF.
    Thanks.
