Hello. Using ADI's LTpowerCAD II V2.7.2 I downloaded the Excel design tool for the LT3759 (see attached). The device is intended for both SEPIC and Boost converters however the design tool appears only to calculate values specific to a Boost converter. Do you have a tool for the LT3759 to calculate SEPIC values, specifically the coupled parallel inductor and recommended SEPIC capacitor value. I understand that the calculations are available in the datasheet however the excel tool is quick to calculate all the relevant values for various possible input conditions and output voltage and power requirements.
Thank You
LeslieXLS
