LTC4020 Strong heating of the inductor and ITH compensation
Good day.
My project uses Vin 9 ... 28 V. Lead acid battery 6 cells .. Charge current 5 A. Load current 10A.
I am faced with the problem of strong heating of the coil with a load of more than 3 A, the coil heats up> 70 degrees. The coil used is such a SRP1770C-4R7M. All mosfet Sir664.
Could it be caused by incorrect compensation work? And can I calculate the denominations of the compensation components for the LTC4020 in the LTPowerCAD program using a project for example for the LTC3780, how true will this be?
Thank you!
  • Thank you WATaylor for your reply.
    • MODE pin is connected to INT_VCC, it is marked with gray text on the diagram and there is no problem with this.
    • The SHDN input is controlled from an external controller, this is also no problem.
    • VIN_REG also does not cause problems and is made according to the technical specifications.
    • Thanks for the diagram, I will test it in practice and give feedback.
    I installed R42 - 97kΩ and C30 - 180pF, diagrams in the screenshots below.
    All measurements were made with an input voltage of 27 Volts, a load current of 8 Amperes, and a charge current of 4 Amperes.
    I tried two kinds of transistors this SiR664DP and BSC016N06.
    VC pin:
    Fig. 1 - VC pin
    SiR664DP:
    Fig. 2 - SW1 (yeelow) SW2 (blue)
    Fig. 3 - Gate SiR664DP
    Fig. 4 - inductor current (I measure across a 0.01Ω resistor)
    BSC016N06:
    Fig. 5 - SW1 (yeelow) SW2 (blue)
    Fig. 6 - Gate BSC016N06
    Fig. 7 - inductor current (I measure across a 0.01Ω resistor)
    The transistors heat up to 70 degrees, the coil now heats up most likely from the transistors. After charging the battery and dropping the charging current to ~ 0, at a load of 8 Amperes, the temperature stabilizes at 55 degrees. Is this a normal temperature? I think it should be less.
    The printed circuit board is 4 layers.
    on Oct 19, 2020 8:27 PM in reply to instalator
    The voltage waveforms (Fig 1, 2, 3, 5, 6) look good.  The current waveform in fig 4 shows no current.  It looks like a measurements error.
    The high frequency ripple in fig 7 must be a measurement artifact.  In fig 7 I see ~100mVp-p (10A), ~4MHz oscillation.  This would imply several hundred volts at 4MHz across the inductor.  4MHz is far from inductor resonant frequency (30MHz), so resonance is not an issue.  The high frequency ripple current waveform is not real.
    Have you measured the efficiency of the converter?  That is the best way to see whether there is excessive power loss.
