Re: [Power Management] - Re: LT8490 Buck-Boost Battery Charge Controller with MPPT
Hi sir,
Here i described the test setup
We are Tested LT8490 charger circuit through DC Voltage (20V) Input Given
to VIN with VINR pin to GND.
Measured BATTERY voltage 12.5V
Connected 12V Lead-acid Battery to LT8490 charger output terminal
Then Switched on the DC supply
we are checked INVCC,GATEVCC,LDO33 these all are got recomended voltage
we did not get clk from CLKOUT
SWENO always low
STATUS led blinking evey 4 sec
FAULT led Always ON
CHARGEDCFG1 We are not used
CHARGEDCFG2 we are not used
followed DEMO MANUAL DC2069A Circuit  and verified with same
Here i am attaching our schematics for your reference
Give us a list of pins to be probed
Can u please resolve this problem.
with regards
R.Rengasamy
LT8490CHARGERCIRCUIT.PDF
  • REPLY FROM:
    we are using LT8490 Buck-Boost Battery Charge Controller with MPPT for one of our solar charger based project.
    we are facing Some problem.we are not get output voltage but INTVCC,GATEVCC and VDD got require voltage.in mean time fault status led blinking every 6 secs
    can you suggest me were the problem persist.
    we are using same DEMO MANUAL DC2069A circuit.
  • REPLY TO
    The LT8490 will measure the battery voltage before starting to charge the battery. The voltage on output terminals must be at least 5V for a 12V battery charger, otherwise the LT8490 will not turn on.
    Can you describe the test setup? Is the power source a solar panel? Is the solar panel illuminated or dark? Do you have a battery attached?
  • Please note that a separate discussion was inadvertently created. The discussion has been deleted and the content moved to this thread.
  • Measure the voltage at FBOUT. It is possible that the ideal diode Q3 is blocking so that the battery voltage does not appear on VOUT_P12V. This means that the LT8490 does not see a battery voltage so it does not start.
    For troubleshooting, short Q3 drain to source.
    Also, check TEMPSENSE pin voltage. And the schematic shows the battery connected in reverse.
    Now our charger circuit working after short Q3 drain to source.
    Thanks for giving feedback
    with regards
    R.Rengasamy
    On Mon, Oct 9, 2017 at 7:42 PM, Tage <
