lt8316
Hi All,
I have a simulated buck converter using LT8316 in the LTspice environment. Although the circuit similar to what shown in picture 7 of datasheet the results are weird. Has anybody this circuit simulated? It seems the chip has no control over output voltage when the load changes!
Thank you for your help
    on Nov 20, 2019 1:35 AM
    Hi ,
    You may not be able to get very good output voltage performance if you are doing very big load changes. There's also a need to have a little bit of load at the output instead of 0A load. It is advantage if you get hold of the buck configuration demo board DC2781A & go through its user manual especially about load requirement to understand better the converters performance.
