As kevint suggested, I made a new question with the part number LT8584.
We are planning to use an ADBMS6830B for our new design and I wanted to combine it with LT8584 balancers. At first this seems impossible because the 6830B does not support the serial interface. That's only integrated in the ADBMS1818 and older LTC681X chips.
Then, I saw that the 8584 can also work in simple mode, which only needs an on/off signal. This signal is very simple to make, because nearly all AFE's on the market have integrated balancing FETs. These FETs can be used to in turn switch an external FET to enable an external discharge resistor, or in this case the enable pin of the 8584. This looks very simple and doable, but I still have some questions.
1. Is it recommended to use the LT8584 in simple mode?
2. Does simple mode affect the safety/diagnostic coverage of the chip? As we need to certify our system up to PLd/SIL2.
3. Do we need to connect the OUT pin to the C pins of our cell monitor? The datasheet states 'The OUT pin defaults to VTEMP, a voltage proportional to the die temperature' but the graph suggests the OUT pin follows Vin as long as the 8584 is in shutdown mode.
4. If all cells are balancing at the same time, we cannot measure the OUT pins anymore, right? Because only cell 1 has a direct ground reference, and the ground reference for cell 2 is the out pin of cell 1. There may be a possibility to use the S pin ADC's to measure back the cell voltage and calculate back the OUT pin voltage, but then the enable pin will be interrupted so this stops the 8584 and we can't measure the state anymore.
Can someone clear up some of these things?
Kind regards,
Robert Jan
