Hi
I was checking the mosfets for shorts on a charger board with the LT8490 IC and while checking the drain-source using the multimeter diode it shows conductivity both ways including source-gate. I though the mosfet was damaged so I checked it again after de-soldering it but its fine, no conduction other than the body diode.
Note 4 on page 5 of the datasheet says :
Do not apply a voltage or current source to these pins. They must
be connected to capacitive loads only, otherwise permanent damage may
occur.
Since the board was unpowered and unconnected, the conduction test could only mean a path through the IC itself. Does that mean the IC is damaged ?
Thank you
