September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
MAX17263
Production
The MAX17263 is an ultra-low power fuel gauge which implements Maxim ModelGaugeâ„¢ m5 EZ algorithm. The MAX17263 monitors either a single cell battery...
Datasheet
MAX17263 on Analog.com
I’m working on a power‑management system that uses the ModelGauge m5 EZ algorithm, and I need help understanding how to properly characterize and configure the fuel gauge for a LiFePO₄ 4‑cell battery pack.
I can connect the battery to the evaluation kit and read data, but the software does not allow me to set a 1 mΩ sense resistor, which is required in my design.
The Software Implementation Guide lists several parameters that need to be written during configuration, but does not clearly explain which ones are essential or how they should be calculated.
