SPI isolator on non isolated batteries
Product Number: AD7284
Hi everyone,
we've a BMS based on a couple of AD7284 devices (AD7284 master and AD7284 slaves connected each other with its daisy-chain line). The BMS handles 16th li-ion cells. The master AD7284 is communicating with a micro controller by using direct SPI bus with no isolation.
The MCU is supplied by one connector, while the AD7284 is connected through a second connector. The two's GND reference of the MCU and of the AD7284 master are the same (negative of the first lithium cell) but comes from a different connector.
The board work well on different thousand of batteries used on industrial market trucks but we've some issue on a specific veichle:
  • sometimes the MCU goes in latch-up. We can reset the batteries only by disconnecting the BMS and connecting it back.
  • sometimes the MCU goes in reset.
It's very difficult to do some debug because the issue is not reproducible.
  1. Hints about debugging techniques ?
  2. I review the datasheet and the EV-board documents of AD7284 and i see is used the SPI isolator in every schematic. It's uses is mandatory? This could be the source of our issues?
Thank you
Best regards
Thread Notes
