- I run into a strange problem. We thought we could use this chip in a simple way by only counting the coulomb counts. We do not do any setup, and just read out the QL and QL register. Sometimes it is counting upwards, sometimes downwards. I tried reading out the cGain register and the value remains the same regardless of counting up or down. We could off course just use absolute value, but it seems that if the couting changing direction, the count is wrong. Is there any more registers that needs to be set up to control this? It is not easy to see the dependencies of the registers in the datasheet
- I want to use RCell Register. Can that be used on primary cell with flat discharge curve LiSOCl2? What other registers need to be set up?
