Separating CSP and GND for more accurate measurements with the MAX17301
Product Number: MAX17301
I have implemented the TQFN version of the MAX17301 in one of my designs. The design uses a large 58 Ah single cell battery. While testing, I missed the fine print which states that the GND reference is tied to CSP for the TQFN package, and I noticed a 100 mV voltage drop when drawing current. My board draws around 3.5 A, and the voltage difference between GND - CSP is within the limits as defined in the electrical characteristics tables. To prevent the voltage drop across the cable from appearing in the measurement, I have updated my design to use the WLP version of the IC; now referencing GND to a sense GND (which is a separate connector from my main battery connector) rather than CSP.
I thought that would solve my problem, but it did not change the characteristics of the measurements at all. Is CSP secretely tied to GND in the WLP package as well, or are all measurements always referenced to CSP anyway? What is GND bonded to in the package?
