I'm doing some test on EVAL-ADBMS1818 with DC2026 Linduino one. The setup is in SPI mode. During the test, i measured the VREG pin and it is 3.2V. The datasheet stated that is should be 5V. As i'm going to design a board and use an external supply of 5V to VREG. I would like to check whether I should supply 5V or 3.3V to this pin.
Thank you.
