I am looking for a simple/complete wireless power transfer solution for a wrist (watch sized) wearable with the following specs:
- Battery Charging not needed, already established (npm1300)
- space constrained, small footprint and low component count
- Wurth Elektronik 760308101219 (Tx) 15mm
Inductance: 11.8 uH Function: Receiver Maximum DC Resistance: 750 mOhms - Wurth Elektronik WR121210-27M8-ID (Rx) 12mm
Inductance: 8.32 uH Function: Receiver Maximum DC Resistance: 950 mOhms Tolerance: 5 % Number of Coils: 1 Coil, 1 Layer Diameter: 12 mm - charge rate is 0.25C, 20mA
- housing will probably be ~2mm of plastic (x2, 4mm total thick) between RX coil and TX coil
- 4v0-5v5 input from the Rx fed to VBUSIN on a Nordic nPM1300 PMIC (battery charger).
LTC4125 appears to be the correct Tx chip, but this is our first WPT design so we have no experience to draw from. I specifically want to ensure
- I have chosen the correct and most current chip.
- Compatible with the Wurth Elektronik 760308101219 (or similar, we are not locked into this one) as far as dimension, inductance, resistance, etc.
I would like to use a Linear Tech Rx chip, but can't identify one that does not include a battery charge system. Is there a chip:
- compatible with Wurth Elektronik WR121210-27M8-ID (or similar, we are dimensionally constrained)
- simply OUT 4v2-5v0 that I can put to VBUSIN on the npm1300 PMIC?
Edit Notes
It appears that I may be able to use the LTC4124 as the Rx chip and simply disable the charge functionality? Leave CHRG unconnected to disable the charger circuitry. Vcc is the rectified output, which defaults to 4.2-4.35v by connecting the FB pin to Vcc (or leaving FB disconnected)? Does that sound right?[edited by: mej at 6:19 PM (GMT -4) on 11 Sep 2025]
