Help with LTC2943 – No I²C Response While Monitoring 14.8V 4S2P Li-Ion Battery
Product Number: LTC2943
We are using the LTC2943 battery gas gauge IC to monitor a 14.8V nominal, 5.7Ah, 4S2P Li-Ion battery pack.
Our setup includes:
  • Sense resistor: 10 mΩ
  • M value: 4096 (based on IBAT/Qmax = 5.7 h)
However, when we try to communicate with the LTC2943 via I²C using an Aardvark I2C/SPI Host Adapter, we are not getting any response (no ACK or valid data from the device).
We’ve double-checked the connections and supply voltage, but still can't confirm whether the IC is functional or not.
Could you please help us with:
  1. Steps to confirm if the LTC2943 is alive and responding on the I²C bus.
  2. Any typical troubleshooting procedures or known issues when using the Aardvark tool with LTC2943.
  3. Any example I²C command sequences or required I²C timings for successful communication.
Any guidance would be greatly appreciated.
