Looking for a Buck-Boost Converter with 5V, 3.3V Buck and 12V Boost Outputs
Product Number: LT1941
Hello ADI Team,
I am working on a power management system where I need a buck-boost converter that can provide:
  • 5V Buck Output
  • 3.3V Buck Output
  • 12V Boost Output
I found the LT1941 buck-boost converter, but the boost channel provides an inverted output, which is not suitable for my design.
System Configuration:
  • The input supply to the buck-boost converter will come from a PMIC, which handles battery charging, solar, external VIN, and USB power management.
  • The VSYS pin of the PMIC can range from 5V to 18V, depending on the available power source.
Requirement:
I need a single IC solution that can:
  • Step down the VSYS voltage to 5V and 3.3V using buck converters.
  • Step up the VSYS voltage to 12V using a non-inverting boost converter.
Is there any alternative buck-boost converter available that meets these requirements?
Thanks in advance for your help!
