MAX77961 - autonomous mode - disable Fast-Charge Timer setting
Category: Datasheet/Specs
Product Number: MAX77961
in our application we use autonomous charging using MAX77961 and MAX77958.
Currently our charging stops after 3 hours because MAX77961 detects timer error. We need to change FCHGTIME settings which specifies length of fast charging.
Can this value be changed in other way than I2C programming? I am looking for some option to disable this timer but at the same time stick with autonomous charging mode (=no programming, all setup done using resistors connected to IC pins).
