Help with Charging Current Issue on Custom Board with MAX17332
Product Number: MAX17332
I have an evaluation board and a custom board, both using the MAX17332 IC.
I used I2C to manually load the same custom configuration onto both boards. However, I’m encountering an issue:
  • On my custom board, the charging current is limited to around 60-80mA.
  • On the evaluation board, using the same configuration, it charges correctly at the desired current.
Could you provide tips on how to debug this issue or suggest where I should start looking?
Thank you,
Shai.
