September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
LTC6813-1
Production
The LTC6813-1 is a multicell battery stack monitor that measures up to 18 series connected battery cells with a total measurement error of less than 2...
Datasheet
LTC6813-1 on Analog.com
I want to add overvoltage and overcurrent protection to this BMS IC, how can I do this? Also, how should I connect to the power supply when using this integrated circuit (development card)? In other words, if it will not be in the form of supply > bms > cell, what can I do to control and protect the cells charged via the supply?
Over/Under voltage thresholds can be programmed by writing to Configuration Register A. LTC6813-1 cannot measure current hence there is no way to detect over current. To measure current we generally recommend ADBMS2950B, this is pack monitor which measures current on the entire pack (this device works with the latest BMS Device from ADI - ADBMS6830B).
The IC will not charge the cells, IC will be powered from the cells themselves, no need to supply any voltage for the BMS to work. If its protection from events occurring due to over voltage/current, you will need to constantly monitor the parameters and disconnect the charging circuit.
Here is an example of how the system can be designed, if you are using latest BMS products 6830B and 2950B:
Thank you for your answer. I will examine the block diagram you sent with my teammates. I may have more questions, I will contact you here. :) Have a nice day!
