Inquiry about the haptic operation on the EVB: No matter what settings I use, the haptic function does not work. There is no output on the port. Even after carefully reviewing the datasheet, I could not find a solution. I would appreciate detailed explanations or materials.
On the EVB, the output of BUCK3 can be turned ON/OFF, but it does not work on the target board. Besides setting the Register Buck3Ena (set E0), are there any other configurations required?
