LTC4013
Recommended for New Designs
The LTC4013 is a high voltage battery charger that is well suited for charging a wide range of lead-acid batteries including both vented and sealed types...
Datasheet
LTC4013 on Analog.com
Hello kiariegabriel
There are several embedded algorithms inside LTC4013 for setting the float and absorption voltage levels.
See pages 15 and 16 (Li-ion charging and mode pins), and Table 1.
Through feedback resistors, you set these levels accordingly, table 1.
Thank you so much for your feedback! I have selected the Li-Ion mode by letting MODE1 and MODE2 float and connected the feedback pin as shown in this diagram:
Will this give me a charging voltage of 4.2 V?
