LTC2959
Recommended for New Designs
The LTC2959 is an ultra-low power battery gas gauge that accurately measures charge, voltage, current and temperature. Its wide input voltage range and...
Datasheet
LTC2959 on Analog.com
My battery charger (Genasun GV-5-MOD) has a pair of "LOAD" terminals to which I have my single board computer (SBC) connected. I want to read the LTC2959 from the SBC.
Should the LTC2959's GND be connected to LOAD- or BATTERY-?
I think if connected to LOAD- then the battery voltage readings will be inaccurate, but if connected to BATTERY- then the I2C lines will have problems due to the SBC having different GND reference. What is best practice here?
You could use a photocoupler but will need extra circuit or you can use a i2c isolator IC. LTC2959 GND should be connected to BATEERY- for accurate measurements.
