Can I seamlessly change input power from Solar Panel to USB charger without I2C programming?
Product Number: LTC4162-F
I'm looking for a solution to charge a battery with a solar panel and an external 5V wall adapter.
I found the LTC4162-F battery charger IC which looks like it is up to the task.
There won't be a microcontroller on the board so no I2C/SMBus is involved.
My schematic will take this as as reference from the datasheet (IC will use MPPT)
Question:
Is it possible to simply swap the solar panel with a 5V USB power supply when desired, or is there more that needs to be done for this?
Thread Notes
