STBY PIN
Product Number: max77787
I need a charging solution that doesn't require communication with a host and that, through a pin being activated or not, the solution is powered or the power is turned off. Would it be possible to achieve this using the STBY pin of the MAX77787, or does the STBY pin only control the USB in this case? If not, what other charger would you recommend?
Thank you.
Thread Notes
