Strong EMC design
MAX17263
Production
The MAX17263 is an ultra-low power fuel gauge which implements Maxim ModelGaugeâ„¢ m5 EZ algorithm. The MAX17263 monitors either a single cell battery...
Datasheet
MAX17263 on Analog.com
Hiya,
I am planning to use MAX17263 in new board design to do battery fuel gauging as well as output voltage cut off at a particular low voltage value by utilising the ALRT pin output.
Battery - 14.54V 7000mAh 4S2P battery. (3.635V single cell nominal voltage)
My questions are,
1. How to setup IC to give alert only based on voltage i.e, only if the battery voltage reaches down to 12V? (Its saying to disable threshold set to the minimum value but how where to find what the minimum value is?)
2. For a 4S2P battery pack all the register/threshold setting based on the single cell used to make the battery pack or based on final battery voltage?
3.How to decide I need to select high side /low side sensing?
SC
Moved from Power Management to Battery Management System on Thursday, November 9, 2023 4:30:26 PM by SBC
Hi, Thank you for your inquiry. Only Maxim ATE products are supported on EngineerZone at this time. Over the next several months, you will see more Maxim products being supported in EngineerZone. Please visit one of the technical support pages on our newly integrated website below for assistance with Maxim Integrated products.
EN - https://www.analog.com/en/support/technical-support.html#
CN - https://support.analog.com/zh-CN/technical-support/
JP - https://support.analog.com/ja-JP/technical-support/
