MAX77962
Production
The MAX77962 is a high-performance wide-input 3.2A buck-boost charger with a Smart Power Selectorâ„¢ and operates as a reverse buck without an additional...
Datasheet
MAX77962 on Analog.com
Hi ADI team,
I'm using the MAX77962 part in my design. Kindly provide the software driver for the same, compatible with Linux version 5.15.71.
Chithraj S
MAX77962 - Moved from Power Management to Battery Management System. Post date updated from Monday, October 23, 2023 to Monday, December 4, 2023 to reflect the move.
Hi, Thank you for your inquiry. Only Maxim ATE products are supported on EngineerZone at this time. Over the next several months, you will see more Maxim products being supported in EngineerZone. Please visit one of the technical support pages on our newly integrated website below for assistance with Maxim Integrated products.
EN - https://www.analog.com/en/support/technical-support.html#
CN - https://support.analog.com/zh-CN/technical-support/
JP - https://support.analog.com/ja-JP/technical-support/
