I'm facing some problems regarding OverVoltage cells (when I check the Status Register Group B). I have a LTC6804-2 with 12 cells connected. The ADC voltage readings are correct:
VC1 = 41538 | VC7 = 40528 |
VC2 = 38785 | VC8 = 40504 |
VC3 = 40256 | VC9 = 40138 |
VC4 = 40219 | VC10 = 40567 |
VC5 = 40232 | VC11 = 40495 |
VC6 = 40532 | VC12 = 40548 |
At the begining I set the voltage thresholds for OV and UV (Configuration Register Group):
voltage_vuv_threshold = 1563 (that it is 2.5 V)
voltage_vov_threshold = 4094 (that it is 8.5V)
After writing this information in to the LTC6804, I read back the register in order to check if those values are properly stored (and they are ok).
Then, I check the Register Group B (CxOV & CxUV flags). All bits related to OV cells are set to 1, no matter what value I set as OverVoltage threshold:
vuv_flags = 0 (all cells haven't gone below 2.5V)
vov_flags = 4095 (all cells have gone above 8.5V)
I do have the suspicius that no matter I'm writing in Configuration Register Group, but value is 0, that is why I don't have UV but I have OV. What it is strange is when I read back the register value it has the values that I wrote.
Any of you have any clue on this?
Thanks in advance,
Roberto
