we are a univerisity project building a BMS for a 400V LiPo accumulator using multiple AD7284s. We know it's deprecated, but this was the only chip available to us.
At the moment we are doing tests with the IC placed on self engineered PCBs. Communication between AD7284 mainand BMS-controller works fine via isoSPI. Now we tried to use the daisychain interface as described at p. 48 of the datasheet. Even so, we get no response from the subordinatevia SPI (e.g. setting device address or reading ADC values).
Therefore, we used an oszilloscope to measure the differential voltages at the daisychain bus. We get a response for the SPI command to init the daisy chain (at least there is an extra pulse in the sequence when the subordinateis connected).
Upper picture shows the daisychain bus without a subordinate connected. Lower picture with connected subordinate.
But we don't get answers over the bus if we do example 2 or 4. So no "extra" communication over the daisychain bus neither a message over isoSPI.
Is there somone who already dealt with this problem?
Also any information on the daisy chain would be highly appreaciated. We don't even see a way of knowing the meaning of the response we get to the init command as the protocol is proprietary.
Thanks.
Left picture shows the daisychain bus without a subordinate connected. Right picture with connected subordinate.
Is there somone who already dealt with this problem or knows some tricks to get this running?
Thanks.
Edit Notes
Changed the label of the pictures.[edited by: Strunk at 10:35 PM (GMT -4) on 26 May 2022]
