Cell balancing on AD7284
Product Number: AD7284
I'm working on the isoSPI interface to the AD7284. We build our own BMS boards with the AD7284 on it. By now we can initiate the first AD7284 over SPI and get the ADC conversion started and get the results back. The watchdog is already disabled. Now we want to test the MOSFETS we used for cell balancing but we can't get the cell balancing outputs activated.
We think that the problem is in the code but we do like described in the datasheet at side 23. We set CBPDB at control register 1 set GOE_CB at control register 3 and all the bits of the cell balance control register. Additionally we write at all the cell balance timer register 0xFF (just for testing).
Each of this register write commands where checked by aksing the AD7284 afterwards for the value of the registers. Anyways the cell balance outputs does not activate. Does anybody know what we do wrong or have a hint what we can check?
Thanks in advance.
