Issue details are
Tool used: Vivado 2021.1
MPSoC Device Used: Xczu3cg-sbva484-1-e
Files used in the project: radiocarbon-13_Testing/bytepipe_sdk-main/src/adrv9001/hdl
High level Issue: Implementation Failed.
Error wind message in VIVADO Tool:
Design Initialization
[Designutils 20-1280] Could not find module 'ila_axis'. The XDC file g:/PULLARAO/TECH/PROJECTS/RADIOCARBON-13/RADIOCARBON-13/PULLARAO/CODES_TESTING/FPGA/project_2.srcs/sources_1/ip/ila_axis/ila_v6_2/constraints/ila_impl.xdc will not be read for any cell of this module.
Place Design
[Place 30-415] IO Placement failed due to overutilization. This design contains 326 I/O ports
while the target device: xczu3cg package: sbva484, contains only 297 available user I/O. The target device has 297 usable I/O pins of which 0 are already occupied by user-locked I/Os.
To rectify this issue:
1. Ensure you are targeting the correct device and package. Select a larger device or different package if necessary.
2. Check the top-level ports of the design to ensure the correct number of ports are specified.
3. Consider design changes to reduce the number of I/Os necessary.
[Place 30-68] Instance adrv9001_rx1_inst/i_serdes/IBUFDS_inst/DIFFINBUF_INST (DIFFINBUF) is not placed
[Place 30-99] Placer failed with error: 'IO Clock Placer failed'
Please review all ERROR, CRITICAL WARNING, and WARNING messages during placement to understand the cause for failure.
[Common 17-69] Command failed: Placer could not place all instances
Below is the issue screen shot
