I have tried to set current range in Choronoamperometry measurements. Based on the 'MethodSCRIPT-v1_4.pdf file, there is no current range settings (in 12th page) in the sample application. So how can I set current range setting for CA? Here is the sample scripts,
var p var c # Select channel 0, set PGStat mode to low-speed and turn on the cell. set_pgstat_chan 0 set_pgstat_mode 2 cell_on # Run a measurement loop for the Chronoamperometry (CA) technique. meas_loop_ca p c 100m 200m 1000m # The following commands are executed after each iteration (measurement). pck_start # Start a new data packet. pck_add p # Add the p variable (potential) to the packet. pck_add c # Add the c variable (current) to the packet. pck_end # Close and transmit the data packet. # At the endloop command, the script execution halts until it is time # for the next measurement loop iteration. endloop
Thank you!
