MethodScript Parameters Based on User Setting
I want to set Chronoamperometry measurement parameters based on user settings such as DC voltage, interval time, and duration of the measurements will set by a user. So how can I automatically update it in the code?
My attempt is like that,
char const * Chrono_Amp = "e\n"
						  "var p\n"
						  "var c\n"
						  "set_pgstat_mode 2\n"
						  "cell_on\n"
						  // A DC potential of 100 mV (EdcChro) is applied. The current is measured every 100 ms (tintervalChro) for
						  // a total of 2 seconds (trunChro). This results in a total of 20 data points at a rate of 10 points per second.
						  //"meas_loop_ca p c 100m 100m 2\n"
						  // Concatenate the other commands
					      printf("meas_loop_ca p c %u %u %u\n", EdcChro, tintervalChro, trunChro);
		    			  "pck_start\n"
		                  "pck_add p\n"
		                  "pck_add c\n"
		                  "pck_end\n"
		                  "endloop\n"
		                  "on_finished:\n"
		                  "cell_off\n"
						  "\n";
I got these errors,
../Core/Src/main.c:225:47: error: expected ',' or ';' before 'printf'
225 | printf("meas_loop_ca p c %u %u %u\n", EdcChro, tintervalChro, trunChro);
../Core/Src/main.c:226:43: error: expected identifier or '(' before string constant
226 | "pck_start\n"
make: *** [Core/Src/subdir.mk:46: Core/Src/main.o] Error 1
"make -j16 all" terminated with exit code 2. Build might be incomplete.
