How to connect an I2C display to EmStat Pico?
To extend the battery powered datalogger I was searching for a simple serial display without too much initialization work to be done at startup and without the need to create any library. The reason for this is, that I wanted to implement the code of the display control inside the MethodScript to demonstrate the standalone capabilities of the EmStat Pico Module.
I think that I will be able to add the example code to the datalogger script to get some human readable feedback during operation.
https://learn.adafruit.com/adafruit-led-backpack/0-54-alphanumeric
The chip used on this board is Holtek HT16K33 with default slave adress 0x70
The first try EmStat Pico example code example is attached. More details will follow.
Thanks to PalmSens for the support!
e # Declare I2C acknowledge bit var a var a # Declare loop var i var i # Declare 16 byte array for sending to HT16K33 device array w 16i # Init var a store_var a 0i ja # Configure I2C GPIOs and set it to 100k clock, 7 bit address set_gpio_cfg 0x0300i 2 i2c_config 100k 7 # Turn on oscillator at HT16K33 array_set w 0i 0x21i i2c_write 0x70i w 1i a # Turn on display at HT16K33 array_set w 0i 0x81i i2c_write 0x70i w 1i a # Adjust dimming array_set w 0i 0xE1i i2c_write 0x70i w 1i a # Init var i store_var i 0i ja # Loop to power off all display segments loop i < 16i array_set w i 0x00i add_var i 1i endloop i2c_write 0x70i w 16i a # Power up segments # Write at address 0x00 array_set w 0i 0x00i array_set w 1i 0xF3i array_set w 2i 0x00i i2c_write 0x70i w 3i a # Write at address 0x02 array_set w 0i 0x02i array_set w 1i 0x09i array_set w 2i 0x12i i2c_write 0x70i w 3i a # Write at address 0x04 array_set w 0i 0x04i array_set w 1i 0x39i array_set w 2i 0x00i i2c_write 0x70i w 3i a # Write at address 0x06 array_set w 0i 0x06i array_set w 1i 0x3Fi array_set w 2i 0x00i i2c_write 0x70i w 3i a # Print var a content pck_start pck_add a pck_end #don't forget to copy the empty line 55 to close the script
I updated the code today.
don't forget a \n at the end of every methodscript. The Code viewer is removing empty lines when uploading examples.
Some useful graphic to get your text created e.g.
"P" == 1111 0011 == 0xF3
"I" == 0000 1001 == 0x09 and 0001 0010 == 0x12
"C" == 0011 1001 == 0x39
"O" == 0011 1111 == 0x3F
