I was able to successful read out the temperature data of ADT7420 using methodscript to access the I2C interface. I used the script example in the methodscript protocol description.
Could you please help and explain how to convert the 16bit into °C?
https://www.analog.com/media/en/technical-documentation/data-sheets/ADT7420.pdf
The datasheet gives only examples for 13bit convention:
