LT1713 protection diodes
Does the LT1713/14 have any integrated protection diodes like those depicted below? If so, which ones, if not, what comparable comparators has integrated diode protection like that depicted here?
Thank you
    Yes, it surely has at the inputs D7 to D10 and outputs D1 to D4 but definitely not D5 and D6 because comparators outputs need to change instantly when a large differential voltage appears at the inputs. When this happens the anti-parallel diodes will conduct current and clamp the differential voltage.
