EVAL-ADPDUCZ F/W update issue
Product Number: ADPDUCZ
Software Version: Application wavetool
We have followed the documentation to upgrade ADPDUCZ firmware, but are facing issues with st-dfu driver as it doesn't get installed by default and installing from st.com (stm32cube-prog) installs stm32 bootloader, which isn't working.
we are not able to figure out how to install ST DFU driver.
I have tried so far following threads:
  1.  EVAL-ADPDUCZ Cannot upgrade the Firmware ( possibly due to driver mis identification)
  2.  RE: EVAL-ADPDUCZ cannot update FW
  • So, Following these steps solves the issue:
    1. Install Application wavetool
    2. Download DfuSe USB device firmware upgrade from st website
    3. Install DfuSe with default paths and settings
    4. Put ADPDUCZ in boot mode by holding BOOT0 and switching on
      1. By this time, Device manager shows STM32 Bootloader as unrecognized device
      2. Update driver by adding following path "C:\Program Files (x86)\STMicroelectronics\Software\DfuSe v3.0.6\Bin\Driver"
      3. Post-installation should show STM Device in DFU mode
    5. Now Firmware update should work fine.
  • The firmware update issue is mainly due to the DFU driver not properly installed. If you have STM32 BOOTLOADER in the Device Manager -> Other devices:
    You will need to right click on STM32 BOOTLOADER and then select Properties:
    In the STM32 BOOTLOADER Properties General tab select Change settings:
    In the same window tab, select Update Driver
    Next, the Update Drivers - STM32 BOOTLOADER window will appear. Select Browser my computer for driver software
    At this step, enter the folder where Applications Wavetool has been installed. Make sure to check Include subfolders and click Next when ready
    Follow the prompt to install DFU mode driver
    Once the DFU driver is installed, you should have the EVAL-ADPDUCZ as STM Device in DFU Mode under Universal Serial Bus controllers:
    Now the driver is updated and the EVAL-ADPDUCZ is ready for firmware update.
    Glen B.
  •    Does this issue is resolved after following the steps mentioned?
    Dinesh
