WaveTool UDP Python connection to send X and Y data from optical sensor
I am working with an EVAL-ADPD2140Z sensor and would like to send the X and Y data from the Angle Application to a Python script. I found this repository https://github.com/analogdevicesinc/ApplicationsWaveTool but I am not sure what data the scripts are sending (seem to be raw channel data from Slot A and Slot B -- example output data is attached) and not sure how to convert that data into X and Y values.
From browsing the past questions on this forum I see that you all have stopped supporting this sensor, but any help would be greatly appreciated, including recommendations for a different sensor to move forward with. The project is to develop a system for eye-tracking using these sensors, placing the position of the pupil based on the centroid of reflected light off the sclera.
[2905.0, 2996.0, 3056.0, 3077.0, 3065.0, 3032.0, 3003.0, 2955.0, 2927.0, 2893.0, 2859.0, 2829.0, 2800.0, 2774.0, 2759.0, 2751.0, 2752.0, 2748.0, 2749.0, 2746.0, 2748.0, 2765.0, 2772.0, 2781.0, 2815.0, 2828.0, 2876.0, 2931.0, 3011.0, 3134.0, 3313.0]
[2528.0, 2650.0, 2696.0, 2673.0, 2624.0, 2580.0, 2526.0, 2477.0, 2427.0, 2382.0, 2342.0, 2308.0, 2274.0, 2260.0, 2248.0, 2233.0, 2225.0, 2223.0, 2225.0, 2227.0, 2231.0, 2240.0, 2259.0, 2277.0, 2308.0, 2355.0, 2420.0, 2496.0, 2608.0, 2756.0, 2940.0]
[3933.0, 4367.0, 4917.0, 5528.0, 6166.0, 6805.0, 7388.0, 7894.0, 8244.0, 8383.0, 8265.0, 7870.0, 7211.0, 6468.0, 5775.0, 5181.0, 4683.0, 4294.0, 3991.0, 3756.0, 3585.0, 3459.0, 3373.0, 3295.0, 3243.0, 3202.0, 3173.0, 3148.0, 3121.0, 3105.0, 3091.0]
[3504.0, 3908.0, 4412.0, 4962.0, 5520.0, 6062.0, 6576.0, 7021.0, 7293.0, 7351.0, 7161.0, 6718.0, 6074.0, 5394.0, 4768.0, 4244.0, 3802.0, 3465.0, 3204.0, 3008.0, 2862.0, 2748.0, 2671.0, 2606.0, 2557.0, 2521.0, 2495.0, 2461.0, 2446.0, 2426.0, 2410.0]
[3069.0, 3064.0, 3065.0, 3064.0, 3070.0, 3075.0, 3076.0, 3076.0, 3082.0, 3079.0, 3088.0, 3095.0, 3094.0, 3109.0, 3110.0, 3111.0, 3110.0, 3110.0, 3116.0, 3114.0, 3115.0, 3112.0, 3106.0, 3107.0, 3102.0, 3101.0, 3103.0, 3107.0, 3096.0, 3093.0, 3088.0]
[2392.0, 2383.0, 2381.0, 2383.0, 2379.0, 2376.0, 2377.0, 2383.0, 2379.0, 2391.0, 2388.0, 2390.0, 2398.0, 2396.0, 2404.0, 2410.0, 2406.0, 2411.0, 2413.0, 2408.0, 2407.0, 2406.0, 2410.0, 2408.0, 2401.0, 2399.0, 2399.0, 2401.0, 2393.0, 2389.0, 2388.0]
[3081.0, 3088.0, 3083.0, 3078.0, 3080.0, 3078.0, 3083.0, 3092.0, 3101.0, 3106.0, 3117.0, 3120.0, 3111.0, 3117.0, 3116.0, 3123.0, 3118.0, 3118.0, 3122.0, 3124.0, 3119.0, 3114.0, 3117.0, 3120.0, 3124.0, 3124.0, 3122.0, 3125.0, 3125.0, 3129.0, 3128.0]
[2383.0, 2380.0, 2378.0, 2382.0, 2383.0, 2384.0, 2384.0, 2392.0, 2393.0, 2397.0, 2400.0, 2400.0, 2406.0, 2407.0, 2410.0, 2412.0, 2405.0, 2401.0, 2406.0, 2405.0, 2407.0, 2411.0, 2408.0, 2411.0, 2406.0, 2414.0, 2416.0, 2416.0, 2405.0, 2410.0, 2414.0]
[3128.0, 3124.0, 3119.0, 3121.0, 3123.0, 3115.0, 3115.0, 3119.0, 3115.0, 3118.0, 3110.0, 3119.0, 3116.0, 3112.0, 3112.0, 3118.0, 3111.0, 3113.0, 3113.0, 3114.0, 3111.0, 3109.0, 3107.0, 3096.0, 3100.0, 3083.0, 3088.0, 3073.0, 3076.0, 3074.0, 3078.0]
[2410.0, 2409.0, 2408.0, 2407.0, 2407.0, 2405.0, 2411.0, 2401.0, 2404.0, 2403.0, 2401.0, 2407.0, 2404.0, 2401.0, 2398.0, 2402.0, 2403.0, 2403.0, 2404.0, 2399.0, 2407.0, 2398.0, 2398.0, 2393.0, 2390.0, 2387.0, 2384.0, 2388.0, 2377.0, 2379.0, 2388.0]
[3082.0, 3088.0, 3088.0, 3080.0, 3090.0, 3078.0, 3075.0, 3073.0, 3067.0, 3059.0, 3063.0, 3055.0, 3051.0, 3056.0, 3051.0, 3058.0, 3044.0, 3047.0, 3044.0, 3047.0, 3049.0, 3056.0, 3064.0, 3070.0, 3067.0, 3078.0, 3076.0, 3083.0, 3091.0, 3089.0, 3101.0]
[2392.0, 2387.0, 2387.0, 2386.0, 2389.0, 2387.0, 2378.0, 2380.0, 2369.0, 2375.0, 2372.0, 2366.0, 2359.0, 2364.0, 2365.0, 2361.0, 2359.0, 2354.0, 2353.0, 2359.0, 2366.0, 2360.0, 2366.0, 2367.0, 2368.0, 2374.0, 2379.0, 2383.0, 2393.0, 2390.0, 2395.0]
[3106.0, 3113.0, 3118.0, 3123.0, 3136.0, 3133.0, 3133.0, 3145.0, 3136.0, 3134.0, 3129.0, 3130.0, 3124.0, 3118.0, 3110.0, 3108.0, 3093.0, 3089.0, 3082.0, 3075.0, 3073.0, 3056.0, 3059.0, 3054.0, 3054.0, 3050.0, 3049.0, 3043.0, 3049.0, 3050.0, 3046.0]
[2408.0, 2413.0, 2412.0, 2420.0, 2425.0, 2428.0, 2428.0, 2437.0, 2430.0, 2433.0, 2431.0, 2425.0, 2428.0, 2420.0, 2422.0, 2423.0, 2411.0, 2405.0, 2405.0, 2408.0, 2400.0, 2401.0, 2400.0, 2397.0, 2393.0, 2393.0, 2397.0, 2396.0, 2404.0, 2404.0, 2398.0]
[3056.0, 3061.0, 3070.0, 3075.0, 3086.0, 3093.0, 3102.0, 3106.0, 3110.0, 3110.0, 3117.0, 3118.0, 3123.0, 3118.0, 3121.0, 3121.0, 3127.0, 3131.0, 3128.0, 3127.0, 3121.0, 3128.0, 3127.0, 3134.0, 3137.0, 3129.0, 3136.0, 3149.0, 3142.0, 3141.0, 3146.0]
[2404.0, 2414.0, 2425.0, 2429.0, 2430.0, 2432.0, 2442.0, 2447.0, 2445.0, 2453.0, 2458.0, 2457.0, 2464.0, 2467.0, 2470.0, 2459.0, 2468.0, 2469.0, 2468.0, 2464.0, 2465.0, 2469.0, 2475.0, 2472.0, 2474.0, 2472.0, 2476.0, 2484.0, 2479.0, 2479.0, 2480.0]
[3152.0, 3150.0, 3157.0, 3164.0, 3163.0, 3162.0, 3158.0, 3149.0, 3150.0, 3140.0, 3132.0, 3129.0, 3125.0, 3118.0, 3118.0, 3118.0, 3119.0, 3114.0, 3114.0, 3105.0, 3106.0, 3094.0, 3095.0, 3093.0, 3090.0, 3082.0, 3075.0, 3072.0, 3062.0, 3052.0, 3050.0]
[2493.0, 2489.0, 2482.0, 2491.0, 2487.0, 2485.0, 2485.0, 2483.0, 2475.0, 2467.0, 2456.0, 2452.0, 2454.0, 2451.0, 2449.0, 2447.0, 2450.0, 2451.0, 2447.0, 2447.0, 2446.0, 2443.0, 2445.0, 2438.0, 2437.0, 2434.0, 2424.0, 2416.0, 2411.0, 2411.0, 2400.0]
[3036.0, 3042.0, 3043.0, 3049.0, 3055.0, 3066.0, 3071.0, 3085.0, 3088.0, 3095.0, 3101.0, 3108.0, 3121.0, 3116.0, 3115.0, 3125.0, 3129.0, 3141.0, 3134.0, 3140.0, 3135.0, 3133.0, 3137.0, 3150.0, 3145.0, 3148.0, 3148.0, 3155.0, 3157.0, 3163.0, 3170.0]
[2393.0, 2398.0, 2408.0, 2407.0, 2415.0, 2421.0, 2429.0, 2434.0, 2446.0, 2445.0, 2454.0, 2451.0, 2456.0, 2459.0, 2458.0, 2464.0, 2476.0, 2476.0, 2479.0, 2472.0, 2475.0, 2470.0, 2473.0, 2470.0, 2478.0, 2477.0, 2480.0, 2485.0, 2480.0, 2488.0, 2492.0]
[3183.0, 3190.0, 3199.0, 3198.0, 3199.0, 3203.0, 3204.0, 3188.0, 3181.0, 3167.0, 3165.0, 3152.0, 3145.0, 3133.0, 3127.0, 3117.0, 3113.0, 3120.0, 3129.0, 3132.0, 3143.0, 3142.0, 3156.0, 3149.0, 3155.0, 3166.0, 3157.0, 3170.0, 3152.0, 3153.0, 3157.0]
[2507.0, 2512.0, 2515.0, 2528.0, 2524.0, 2519.0, 2513.0, 2504.0, 2499.0, 2492.0, 2484.0, 2470.0, 2464.0, 2456.0, 2452.0, 2446.0, 2454.0, 2459.0, 2469.0, 2473.0, 2477.0, 2481.0, 2486.0, 2492.0, 2494.0, 2507.0, 2504.0, 2506.0, 2504.0, 2494.0, 2505.0]
[3196.0, 3202.0, 3219.0, 3231.0, 3234.0, 3256.0, 3265.0, 3278.0, 3280.0, 3297.0, 3304.0, 3313.0, 3312.0, 3318.0, 3313.0, 3321.0, 3325.0, 3323.0, 3324.0, 3332.0, 3334.0, 3329.0, 3332.0, 3335.0, 3323.0, 3327.0, 3317.0, 3307.0, 3305.0, 3293.0, 3296.0]
[2527.0, 2538.0, 2546.0, 2551.0, 2565.0, 2566.0, 2575.0, 2587.0, 2594.0, 2600.0, 2606.0, 2608.0, 2608.0, 2609.0, 2609.0, 2607.0, 2606.0, 2609.0, 2601.0, 2607.0, 2607.0, 2602.0, 2603.0, 2604.0, 2595.0, 2601.0, 2586.0, 2581.0, 2575.0, 2576.0, 2579.0]
[3327.0, 3351.0, 3363.0, 3375.0, 3389.0, 3393.0, 3387.0, 3381.0, 3371.0, 3364.0, 3352.0, 3347.0, 3335.0, 3317.0, 3306.0, 3301.0, 3296.0, 3298.0, 3307.0, 3307.0, 3308.0, 3318.0, 3322.0, 3338.0, 3347.0, 3359.0, 3359.0, 3357.0, 3365.0, 3386.0, 3377.0]
[2600.0, 2612.0, 2635.0, 2649.0, 2648.0, 2672.0, 2665.0, 2667.0, 2657.0, 2655.0, 2655.0, 2648.0, 2642.0, 2631.0, 2629.0, 2621.0, 2624.0, 2627.0, 2629.0, 2635.0, 2643.0, 2647.0, 2651.0, 2662.0, 2668.0, 2672.0, 2671.0, 2675.0, 2681.0, 2680.0, 2685.0]
[3381.0, 3385.0, 3373.0, 3363.0, 3361.0, 3356.0, 3346.0, 3332.0, 3317.0, 3310.0, 3300.0, 3298.0, 3290.0, 3281.0, 3269.0, 3269.0, 3265.0, 3261.0, 3276.0, 3282.0, 3293.0, 3312.0, 3314.0, 3315.0, 3310.0, 3291.0, 3282.0, 3270.0, 3246.0, 3224.0, 3180.0]
[2682.0, 2679.0, 2672.0, 2661.0, 2645.0, 2644.0, 2627.0, 2628.0, 2616.0, 2599.0, 2590.0, 2589.0, 2582.0, 2581.0, 2571.0, 2569.0, 2563.0, 2567.0, 2566.0, 2576.0, 2588.0, 2602.0, 2609.0, 2613.0, 2607.0, 2596.0, 2586.0, 2578.0, 2556.0, 2537.0, 2516.0]
[3130.0, 3109.0, 3095.0, 3082.0, 3074.0, 3063.0, 3071.0, 3086.0, 3101.0, 3118.0, 3138.0, 3158.0, 3173.0, 3182.0, 3187.0, 3199.0, 3200.0, 3203.0, 3201.0, 3198.0, 3194.0, 3190.0, 3181.0, 3189.0, 3189.0, 3193.0, 3194.0, 3191.0, 3186.0, 3186.0, 3163.0]
[2475.0, 2466.0, 2446.0, 2437.0, 2433.0, 2429.0, 2438.0, 2444.0, 2452.0, 2471.0, 2488.0, 2502.0, 2508.0, 2517.0, 2526.0, 2533.0, 2538.0, 2541.0, 2531.0, 2532.0, 2525.0, 2523.0, 2518.0, 2515.0, 2521.0, 2521.0, 2519.0, 2515.0, 2506.0, 2492.0, 2480.0]
