How to drive the LED in ADPD4101 sensor?
We are using ADPD4101 sensor which is using I2C interface. I am unable to drive the LED which is present in ADPD4101 sensor.
I have attached my code snippet here. I am looking ahead for your suggestion on ADPD4101 sensor LED drive.
int32_t adpd410x_reg_read(nrf_drv_twi_t const *p_instance, uint16_t address, uint16_t *store_data)
	uint32_t ret_code;
	uint8_t buff[] = {0, 0, 0, 0};
        buff[0] = ((address >> 8) & 0x00ff) | 0x80;
        buff[1] = address & 0xff;
        /* No stop bit */
        ret_code = nrf_drv_twi_tx(p_instance, HRM_I2C_ADDRESS, buff, 2, true);
        if(ret_code != NRF_SUCCESS)
           return ret_code;
        ret_code = nrf_drv_twi_rx(p_instance, HRM_I2C_ADDRESS, (buff + 2), 2);
           return ret_code;
	*store_data = ((uint16_t)buff[2] << 8) & 0xff00;
	*store_data |= buff[3] & 0xff;
	return NRF_SUCCESS;
 * @brief Write device register.
 * @param address - Register address.
 * @param data - New register value.
 * @return NRF_SUCCESS in case of success, FAILURE otherwise.
int32_t adpd410x_reg_write(nrf_drv_twi_t const *p_instance, uint16_t address, uint16_t data)
          buff[2] = (data >> 8) & 0x00ff;
          buff[3] = data & 0xff;
        return nrf_drv_twi_tx(p_instance, HRM_I2C_ADDRESS, buff, 4, false);
 * @brief Do a software reset.
int32_t adpd410x_reset(nrf_drv_twi_t const *p_instance)
	int32_t ret;
	ret = adpd410x_reg_write(p_instance, ADPD410X_REG_SYS_CTL, BITM_SYS_CTL_SW_RESET);
	if(ret != NRF_SUCCESS)
          return ret;
uint16_t reg_temp_1, val_1;
void get_ADPD4_chip_ID(nrf_drv_twi_t const *p_instance, uint8_t i2c_line)
        int32_t ret_code;
	ret_code = adpd410x_reg_read(p_instance, ADPD410X_REG_CHIP_ID, &reg_temp_1);
	if(ret_code != NRF_SUCCESS){
          NRF_LOG_INFO("HRM I2C read failure");
          return;
        val_1 = reg_temp_1 & BITM_CHIP_ID;
        if((val_1) == (uint16_t)ADPD410X_CHIP_ID){
            NRF_LOG_INFO("ADPD4101 CHIP-ID read success");
        else{
            NRF_LOG_INFO("ADPD4101 CHIP-ID read failure");
 * @brief Set operation mode.
int32_t adpd410x_set_opmode(nrf_drv_twi_t const *p_instance, uint16_t opmode)
	return adpd410x_reg_write(p_instance, ADPD410X_REG_OPMODE, opmode);
 * @brief Set number of active time slots.
 * @param timeslot_no - Last time slot to be enabled.
int32_t adpd410x_set_last_timeslot(nrf_drv_twi_t const *p_instance, enum adpd410x_timeslots timeslot_no)
	return adpd410x_reg_write(p_instance, ADPD410X_REG_OPMODE, timeslot_no);
 * @brief Set device sampling frequency.
 * @param sampling_freq - New sampling frequency.
int32_t adpd410x_set_sampling_freq(nrf_drv_twi_t const *p_instance, uint32_t sampling_freq)
	int32_t ret;
	uint32_t reg_load;
	uint16_t reg_temp;
#if 1
        ret = adpd410x_reg_read(p_instance, ADPD410X_REG_SYS_CTL, &reg_temp);
            return ret;
        if(reg_temp & BITP_SYS_CTL_LFOSC_SEL)
            reg_load = ADPD410X_LOW_FREQ_OSCILLATOR_FREQ1;
        else
            reg_load = ADPD410X_LOW_FREQ_OSCILLATOR_FREQ2;
        reg_load /= sampling_freq;
#endif
	ret = adpd410x_reg_write(p_instance, ADPD410X_REG_TS_FREQ, (reg_load & 0xFFFF));
          return ret;
int32_t ADPD410x_device_setup(nrf_drv_twi_t const *p_instance, enum adpd410x_timeslots m_timeslot_no, uint8_t i2c_line)
        int32_t ret;
        uint16_t data;
        data = 0x4000;                           //Enable Channel 2
	ret = adpd410x_reg_write(p_instance, ADPD410X_REG_TS_CTRL(m_timeslot_no), data);       //0x0100
            return ret;
        if(i2c_line == 1)
            data = 0x1000;                       //IN2 connected to VC1...IN7
            ret = adpd410x_reg_write(p_instance, ADPD410X_REG_INPUTS(m_timeslot_no), data);   //0x0102
                return ret;
        else
            //m_timeslot_no = 6;                 //Setup inputs
            data = 0x4043;                       //IN2 connected to VC1...IN4, IN8 connected to VC2
            ret = adpd410x_reg_write(p_instance, ADPD410X_REG_INPUTS(m_timeslot_no), data);   //0x01C2-G slot //0x0102
                return ret;
	data = 0x0E0E;                       //21 mA output current & slot A has been selected 1A, 2A
	ret = adpd410x_reg_write(p_instance, ADPD410X_REG_LED_POW12(m_timeslot_no), data);  //0x0105
            return ret;
        data = 0x0E0E;                       //21 mA output current & slot A has been selected 3A, 4A
	ret = adpd410x_reg_write(p_instance, ADPD410X_REG_LED_POW34(m_timeslot_no), data);  //0x0106
            return ret;
        data = 0xFF0A;                       //Pulse width max & offset max/2
        ret = adpd410x_reg_write(p_instance, ADPD410X_REG_LED_PULSE(m_timeslot_no), data); //0x0109
            return ret;
#if 0
        data = 0x1E00;                       //21 mA output current & slot B has been selected 4B
        ret = adpd410x_reg_write(p_instance, ADPD410X_REG_LED_POW34(m_timeslot_no), data);  //0x0126
            return ret;
#endif
int32_t adpd410x_set_clock_freq(nrf_drv_twi_t const *p_instance)
      int32_t ret;
      ret = adpd410x_reg_write(p_instance, ADPD410X_REG_SYS_CTL, 0x0002);    //1 Mhz low freq internal oscillator selected
        return ret;
void init_ADPD410x(nrf_drv_twi_t const *p_instance)
        adpd410x_reset(p_instance);                 //SW reset
        adpd410x_set_opmode(p_instance, BITP_OPMODE_OP_MODE);  //standby mode
        adpd410x_set_clock_freq(p_instance);        //1 Mhz sampling freq
        //adpd410x_set_sampling_freq(p_instance, SAMPLING_FREQ);   //For 1MHz freq - Sampling rate will be 100Hz
        adpd410x_set_last_timeslot(p_instance, ADPD410X_TS_A); //Time slot A
main()
/*Check ADPD4101 sensor */
      get_ADPD4_chip_ID(&m_twi, I2C_LINE0);
      get_ADPD4_chip_ID(&m_twi_1, I2C_LINE1);
      ADPD410x_device_setup(&m_twi, ADPD410X_TS_A, I2C_LINE1);
      nrf_delay_ms(10);
      ADPD410x_device_setup(&m_twi_1, ADPD410X_TS_A, I2C_LINE0);
      nrf_delay_ms(10);
      adpd410x_set_opmode(&m_twi, 0x0001);  // Changing from standby mode to Go mode
      adpd410x_set_opmode(&m_twi_1, 0x0001); // Changing from standby mode to Go mode
Regards
Sudharsan
  • +1
    on Jun 10, 2021 3:47 PM
    Hi  Sudharsan,
    Have you verified if your register read & write are working?
    With regard to the LED drivers, can you let us know your schematic of the LED(s) and/or PD(s)? The LED drivers of ADPD4101 are current sink and the LED(s) should be supplied with VLED.
    Glen B.
  • Hi Glen,
    Thanks for your reply.
    I2C read/write is working fine. LEDs are 1A, 2A, 3A, 4A and 4B
    I have resolved it, as I was not turning on the 1MHz LF OSC
    Its working. I am moving forward to do PPG measurement.
    I'll give you an update on PPG stuffs. I need your support on this sensor's software development, as I am new to this.
    Thanks and Regards
    Sudharsan
    on Jun 11, 2021 1:26 PM in reply to SK377
    Thanks Sudharsan! Let us know if you need assistance.
    Glen B.
  • Hi Glen,
    I need your support on PPG measurements and I hope you know that I am using ADPD4101 sensor
    I have configured following registers
    1. Standby mode during write operations, Go mode after write operation
    2. 1 MHz LF Oscillator
    3. FIFO interrupt configured and Watermark level set to 20 bytes and GPIO 0 pin configured as an interrupt
    4. LEDs 1A, 2A, 3A, 4A, 4B configured with appropriate current settings - Able to operate
    5. Sampling frequency - 300 Hz
    6. Timeslot A has been selected - I request you to give me more information about Timeslots
    a) How many Timeslots can be used ? Currently I have used only Timeslot A. Is there anything like, we have to use only Timeslot A and  B for LEDs. C and D for Inputs/ GPIOs. Please clarify the same. I have also attached My HRM sensor schematic
    7. LED pulse width and offset 20us and 16us respectively
    8. In Register 0x0100 written value = 0x4000       Enable Channel 2   //<! impulse mode with offset = 0
    9. In Register 0x0101 written value = 0x00E6      Skip preconditioning, Band pass filter bypassed
    10. In Register 0x0110 written value = 0x0003     Configure number of bytes - 3 bytes (Max 4 bytes)
    11. TIA gain 100k and Vref = 0.88v
    12. In Register 0x0107 written value = 0x010C    No. of ADC pulses
    13. In Register 0x0108 written value = 0x1000     float mode, minimum period
    14. In Register 0x010A written value = 0x0203     Integrator pulse width, bandpass filter powered down
    15. In Register 0x010B written value = 0x01A0    Integrator pulse timing offset
    16. In Register 0x010C written value = 0x0210    Modulation pulse width and offset
    17. In Register 0x010C written value = 0x0210    IN2 connected to VC1...IN4, IN8 connected to VC2
    b) I need to read the Channel 1 and Channel 2. How do I specifically read from channel 1 and Channel 2 ??
    c) Currently I am getting 3 bytes from FIFO on every single read. How do I verify whether I am receiving correct PPG outputs.
    I thought that I would get 20 bytes after periodic read from FIFO. But I have got 3 bytes every time. What is that DATA FORMAT bytes actually that I configured with ?
    d)  Decimation factor - I did not set this register. What do I need to set with ? or Does this very essential to set? (This is to calculate ODR right ??)
    e) Does it have standard sampling mode and Digital Integration mode ? If so, need to know detailed information.
    f) What is the Dark signal registers for?  and  What is the Lit signal registers for?
    Regards
    Sudharsan
  • +1
    on Jun 15, 2021 6:55 PM in reply to SK377
    Hi Sudharsan,
    You can find the answers to most of your questions in the ADPD4100/ADPD4101 datasheet. You can start with simple configuration such as those come with our evaluation software Applications Wavetool.
    For your convenience, please refer to my comments below:
    The ADPD4101 supports up to 12 timeslots. There is no specific application associated with any timeslot. You can use a timeslot for any measurement. The input pins can be configured different in each timeslot. The GPIOs can be configured quite differently. Please refer to register map for registers 0x0023 and 0x0024 for details.
    You can enable CH2 by setting bit[14] of register 0x0100 for timeslot A, register 0x0120 for timeslot B, and so on. The data in the FIFO is organized sequentially as timeslot A, timeslot B, ... For instance, if you have timeslots A with CH1, timeslot B with CH1 & CH2, and timeslot C with CH1, then the data stream as following: [A_CH1]-[B_CH1]-[B_CH2]-[C_CH1]-[A_CH1]]-[B_CH1]-[B_CH2]-[C_CH1]- ..., depending on your FIFO threshold setting in register 0x0006.
    I am not sure how your code reads the FIFO. Please check if it reads all the data in the FIFO for each FIFO interrupt handling.
    The decimation factor is for reducing the ODR. Check the register map of register 0x0112/0x0132/0x0152... for details.
    The ADPD4101 supports multiple acquisition mode, including float mode, continuous mode, digital integration mode, and other modes. Refer to the datasheet for details.
    In measurement with photodiode (PD), there is very small dark current with no photons hitting the PD if the PD is reverse biased (that is very typical for PD to achieve fast response). The dark current is acquired as dark signal and saved in the dark signal register. The LIT is the sample when there are photons hitting the PD. Lit minus Dark will give the true photocurrent. Please refer to Figure 23 in the datasheet for details.
    Glen B.
