Question about the problem that ADPD4101 does not operate normally when power-up.
My client made 6 of them using the parts below.
-Part No. : ADPD4101BCBZR7
-Date code: 2016
After power-up, 3 of them operate normally (addr 0x08, value 0x2c2), but the remaining 3 are read as CHIP_ID (addr 0x08) as 0x0000.
For reference, My client controlled through the CPU with the following items in 'errata for Preliminary Datasheet'.
Please answer if it is necessary.
At every power-up of the ADPD4100/ADPD4101, please use the following register sequence:
1.GPIO0 must either be driven to, or pulled up to, IOVDD at the start-up. This can either be performed by driving the GPIO 0 pin high from the microcontroller or by a weak pull-up to IOVDD (>1MΩ).
2. Write register 0x00B5 to 0x0004. This writes REGISTER_INIT bit to 1.
3. Write register 0x00B5 to 0x0000. This writes REGISTER_INIT bit to 0.
4.If GPIO0 is driven high by the host, it can be released at this point.
