Good Morning,
I would to know the number of pulse in both modes (Float mode & normal mode)??
Hello
The number of pulses is defined by the user and programmed into a register. More pulses yields higher SNR at the rate of sqrt(# pulses). So for every doubling in pulses you would expect 3dB increase…
The number of pulses is defined by the user and programmed into a register. More pulses yields higher SNR at the rate of sqrt(# pulses). So for every doubling in pulses you would expect 3dB increase in SNR.
Kevin
