On the ADPD 2212 what is the calculation for select the Rs value on figure 13 of the datasheet, for choose the gain?
ADPD2212
Obsolete
The ADPD2212 is an optical sensor optimized for biomedical applications. Very low power consumption and near theoretical signal-to-noise ratio (SNR) are...
Datasheet
ADPD2212 on Analog.com
The value for Rs is should be set by the application. The ADPD2212 has an internal current gain of 24x, and it has an input referred noise floor of ~100fA. Rs should be set such that the brightest signal being measured does not saturate the ADC, and such that the noise floor is dictated by the ADPD2212 and not by the ADC resolution.
