Stall Guard result is not varying enough to use cool step
The user is experiencing limited resolution of the SG result when using a small stepper motor (SY20STH30-0604) with the TMC5240 eval kit. The final answer suggests using StealthChop and StallGuard4 for better performance with small motors. The user acknowledged the advice and will try the recommended configuration.
Product Number: TMC5240
I am using a small stepper motor (SY20STH30-0604A) to spin a worm drive, and it worked great. But now I am trying to use the cool step functionality because I am having heat issues. I have the TMC5240 eval kit, and I am looking at the SG result value, which drives cool step, and I see that the SG result does not vary much if I apply a heavier load and only drops around 10 units until the load gets too heavy and it stalls. I was wondering if there is any way to blow up the resolution of the SG result? Like instead of varying 10 units I could make it vary 100?
