I have a question about the body diode of the FET inside the max22201.
Are there any specified values for reverse current?
KCC's Quizzes AQQ304 - A pure logic
1. Quote of the month: "I am not lazy, I'm just in energy-saving mode" - unknown
2. Quiz AQQ304 about finding a pure logic puzzle
Mike is looking at Anne, but Anne is looking at Paul.
Mike is married, but Paul is not.
Question:
Is a married
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
MAX22201
Production
The MAX22201/MAX22202/MAX22207 integrate one
36V, 3.5A peak full bridge capable of driving one brushed
DC motor. The full bridge features very low impedance...
Datasheet
MAX22201 on Analog.com
jnaso - Moved from Interface and Isolation to Motor Control Hardware Platforms. Post date updated from Wednesday, January 14, 2026 6:59 AM UTC to Thursday, January 22, 2026 4:43 PM UTC to reflect the move.
I would appreciate it if you could get back to me right away.
best regards
I'm going to move this question to the Motor Control forum. You should get an answer here
I cannot specifically say for this IC- but I can say generally what we do in our drivers:
The body diodes in all of our drivers are rated for the same current as the power MOSFETs themselves, as they take over part of the current in each cycle. However, body diode forward voltage is high, and therefore they lead to large power losses and conduction time needs to be kept low to avoid overheating. To address this, our power drivers actively switch on the MOSFETs when diode conduction is determined to reduce body diode current.
Hope this helps.
Thank you very much for your detailed explanation.
Your description was very helpful and clarified our understanding well.
We appreciate your support and the time you took to explain this.
